2/16/2006 8:20 AM | |
Posts: 3149 Rating: (171)
Hi cykee, if you are using a S7-CPU this FAQs may be interesting for you: http://support.automation.siemens.com/WW/view/en/22028441 http://support.automation.siemens.com/WW/view/en/21737406 http://support.automation.siemens.com/WW/view/en/19036812 Nemo |
2/16/2006 9:13 AM | |
Hi, perhaps using WinCC OPC HDA would be an option for you? http://support.automation.siemens.com/WW/view/en/21320307 in the WinCC online help you can find some additional information as well. triggering an alarm with time stamp by changing a bit-value is of course no problem [:D] nemo |
2/17/2006 10:39 AM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating: (151)
An alternative method is to have a Global Action that triggers your alarm when your condition is true. |
