9/20/2005 11:12 AM | |
Posts: 3609 Rating:
Hi: There's only the manual about Profibus DP on A&D website.Does anybody know something about Profibus PA? Thanks! |
Joined: 8/10/2005 Last visit: 4/9/2024 Posts: 1486 Rating:
I have searched for "PROFIBUS PA" within the Product Support This are 2 of the documents i found: http://support.automation.siemens.com/WW/news/en/1971286 http://support.automation.siemens.com/WW/news/en/1174285 Hope this information helps greatings Sabine |
Last edited by: CS Moderator at: 10/31/2005 1:50 PMLast edited by: CS Moderator at: 10/12/2005 1:38 PM |
7/17/2012 2:40 PM | |
Joined: 9/27/2006 Last visit: 7/8/2024 Posts: 12268 Rating:
Hello Mazen; Most of your answer is spot on correct, but I must point out that Profibus PA does not use RS-485 to exchange data. It uses MBP (Manchester coded, bus powered) protocol, under specs for the FISCO model which are the same as used by Foudation Fieldbus. This why a DP/PA coupler (or DP/PA link) is required to communicate with PA instruments fromthe Profibus-DP network. You will find more information and links in the following discussion: /tf/WW/en/Posts/66310 Hope this helps, Daniel Chartier |
3 thankful Users |
3/9/2017 9:55 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4770 Rating:
New question published by baban is split to a separate thread with the subject Parameters required to connect a drive to plc. Best regards |
3/9/2017 10:10 AM | |
Posts: 531 Rating:
https://en.wikipedia.org/wiki/Profibus There is a good description about the differences, too! |
