(0)| 3/16/2023 2:14 PM | |
Joined: 8/3/2009 Last visit: 1/15/2026 Posts: 16635 Rating:
Hello byahya --> Just an alternative: Why do you want to work with Pack&Go. The Solution with Offline Transfer works a lot better and you do not have to fight with preconditions and so on: https://support.industry.siemens.com/cs/de/en/view/109740696 Just use a USB Device or SD Card. You can send the Files also electronical to customer and so on... I have done many times and I would not use Pack &Go again... (you can also update OS with offline Transfer) Bye Murof |
Last edited by: Murof at: 03/16/2023 14:14:45Last edited by: Murof at: 03/16/2023 14:14:59If this Information really helps, you could use the Rate function |
