(0)| 2/19/2007 10:55 AM | |
Posts: 3149 Rating:
Hi, I had a try with my V6.1 and it worked with the CH_AI driver block. In HW-Config you´ve to use a 6ES7 331-7PF00-0AB0 nemo |
| 2/20/2007 2:33 PM | |
Posts: 7 Rating:
Hi Thaku I use6ES7 331-7PF00-0AB0and compilation now is ok. But after when i want to see value of CH_AI Driver insted of min_rang= 0 and max_range=100 the value of output is in 4260 means that out of range of course qbad=0 and quality=80. how can solve this problem? |
| 3/12/2007 3:18 PM | |
Joined: 9/1/2005 Last visit: 1/9/2026 Posts: 4114 Rating:
Closed: cause new question is also posted in a new thread. Here you will find the new topic:Wrong Value Reading From 6ES7 331-7PF00-0AB0 in the same conference. Best regards CS Moderator |
