6/26/2007 3:39 PM | |
Posts: 1776 Rating:
Hi, You can do this with the User archive table control. See the Online help Options > User Archives > WinCC User Archives table Control Also have a look at the FAQ http://support.automation.siemens.com/WW/view/en/24363822 Best regards April |
6/27/2007 9:31 AM | |
Posts: 14 Rating:
Hi, dear "Expert" - all of you. I think somebody ask you for "real" script - code and i think he doesn't ask you for some FAQ or part of manual. Please look at attachment. THIS IS THE "REAL" ANSWER. Probably you'd check russian siemens forum.(use google). I've got feeling that forum's getting worts. Salma (this your web http://www.wincc.net/). why did you stop to upgradethose pages? It helped me to learn WinCC a lot. For marcius: Attached function runs without any problems in the real application. Sort description: Function creates a new archive table and adds a few fields (date, text, float) to this table. There a many useless code in the function, but i'm sure you'll find what you asked surely. Keep on mind: This function uses CS function from ODK. It's not allowed to open CS connection if RT connection is already opened and vice-versa(more infoin ODK manual.You must check it.No choice). Don't open "UserArchive" editor if CS function runs(It uses something like RT connection as well). That causes error return value from function. And there're so many restriction about redundancy configuration and accsesfrom client.You intend to use to add some (200) UAfields, than it'd be OK.Good luck in looking for. AttachmentAddNew_UserArchive.zip (359 Downloads) |
6/27/2007 2:58 PM | |
Joined: 10/12/2006 Last visit: 6/3/2025 Posts: 70 Rating:
Thank you for this script! It made my life easier |
