2/28/2022 1:52 PM | |
hi PEDROBORGES, Not every analog input module works the same. The other card should be projected in the sam way as the old one. What do you want to measure? What modules are you talking about exactly? This manual about S7-300 modules contains the information you need to know about the modules: S7-300 Module datahope this helps, regards, |
FCK WAR! |
2/28/2022 6:37 PM | |
Joined: 1/7/2022 Last visit: 3/2/2022 Posts: 4 Rating:
thanks , I just need to change the hardware configuration to AI 8x16 Bit and it works ? |
3/1/2022 11:59 PM | |
thanks , I have five busy analogs that work in current form. Will I have to make changes to the connections?
