1/3/2017 8:37 AM | |
hi igor_tmp, do it like it is described in the manual. If all LED are flashing, the manual says:
SIMATIC S7-300 CPU 31xC and CPU 31x: Installation share the diagnostic buffer with us, then we can say more about this behavior. hope this helps, regards, |
FCK WAR! |
1/3/2017 1:08 PM | |
Joined: 7/20/2015 Last visit: 3/24/2025 Posts: 154 Rating:
Hello, igor_tmp Your CPU have internal error I suggest you to open a Support Request Because i already suffered from this problem. SANDEEP Bakoliya |
Regards |
1/3/2017 11:12 PM | |
Joined: 6/30/2010 Last visit: 3/6/2023 Posts: 4 Rating:
Thank you all for your support.Began to carry out your recommendations. |
1/5/2017 5:42 AM | |
The problem continues. Attached file of diagnostics buffer after failure. AttachmentServiceData_CPU 319F-3 PN-DP_R00S02.txt (540 Downloads) |
1/5/2017 12:09 PM | |
hi Igor, I had a look to the Diagnostic Buffer you sent us.
after that event a memory reset was requested and done. As already mentioned I recommend you to open a Support Request Send them the Diagnositc Data. They can say you exactly what happened and what you can do. regards, |
FCK WAR! |
