4/21/2010 10:55 AM | |
Posts: 11 Rating:
Hi, I've installed Wincc v5.0 , pcs 7 v6.1 sp1 under Windows 2000 professional SP4; I am using CP1613 A2 card; But at PG/PC interface settings I couldn't see andchoose CP1613. What should I do? Thanks. Splitted from can I install Wincc 4.0 and pcs 7 on dell optiplex gx110 PC with windows 2000 OS?. |
4/23/2010 10:46 AM | |
Joined: 4/5/2006 Last visit: 7/30/2025 Posts: 917 Rating:
Hi kylmaz, here link to check compatibility between Windows and SIMATIC NET version. Which SIMATIC NET Industrial Ethernet PC CP is compatible with which Microsoft Windows operating system? seems your configuration is good, but...it's no possiblwe to install WinCC and PCS7 on the same partition. can you explain a lil better what is your configuration? regards |
