11/11/2024 2:42 PM | |
Joined: 8/3/2009 Last visit: 9/5/2025 Posts: 16349 Rating:
Hello Trocken It has to be a safe connection, so install first the correct Webserver certificate: https://support.industry.siemens.com/cs/de/en/view/109806850 Also you should try to use the coputername instead of IP (depends on what you have set in your certificate) Check the Documentation in the FAQ: https://support.industry.siemens.com/cs/de/en/view/109827849 Bye Murof |
