6/25/2025 4:33 AM | |
Joined: 4/9/2025 Last visit: 8/18/2025 Posts: 1 Rating:
Dear sir , could you please send me the code/ vb script for sending data from wincc runtime to excel via ODBC? actually i want to check the connectivity between wincc runtime & odbc. or can you send me the procedure to check the wincc runtime to odbc connectivity ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 06/25/2025 06:37:38New subject after splitting |
6/25/2025 12:23 PM | |
Joined: 8/3/2009 Last visit: 9/4/2025 Posts: 16343 Rating:
Hello @AutoGen_94140 Which WinCC Version do you use exactly? Are you shure you mean excel and not SQL Server? I only know ODBC connection to databases in VB Script by using WinCC. If you want to get access to Excel with MS automation interface on the same PC you can use this example: https://support.industry.siemens.com/cs/ww/en/view/109976624/139193407371 Bye Murof |
