12/31/2015 12:05 PM | |
Hello, These outputs can be used in a so called 3 step controller: This has nothing to do with a true "step motor" that is used for positioning. Could you be more specific on the "step motor" you want to use? |
1/3/2016 10:50 AM | |
Hello, It also works with two outputs with opening pulses and closing pulses. You than call the FC1 in a time triggered OB (OB35). To be tested ... AttachmentFB42.pdf (318 Downloads) |
Best regards |
