5/8/2019 5:02 PM | |
Joined: 5/3/2017 Last visit: 2/6/2025 Posts: 673 Rating:
Hello Mahesh N, in the manual Compendium Part C - Equipment Phases with SFC Types (V9.0) at section Technological configuration of equipment modules and equipment phases you can find a solution for this if you use EPH and EMT. With regards |
5/8/2019 8:07 PM | |
Joined: 2/1/2010 Last visit: 9/12/2025 Posts: 212 Rating:
Hello, A more helpful section of that manual might be: You don't have to use EMT or EPH in order to accomplish this. |
If my post helped you, please rate. Thanks. |
5/9/2019 2:22 PM | |
I think there are two ways, depends on what you want to do: You can make a new CMT for the shared block. Then the shared resource block tech IO connects to the original CMT and to the EMT for commands. EMT connects to the shared resource block tech IO for commands and the original CMT for feedbacks. Or you can change your CMT to incorporate the shared resource block and modify all your tech IO there. This way you would have just one place to interconnect EMT to CMT tech IO. |
