12/15/2006 3:54 PM | |
Joined: 4/24/2006 Last visit: 7/31/2025 Posts: 9027 Rating:
Hi hambar, I hope I can help: Problem 1: Have you seen this faq: http://support.automation.siemens.com/WW/view/en/18208090 Please have a look at point 5. This can help to find data from specifiek slave. Problem 2: Have you seen this faq: http://support.automation.siemens.com/WW/view/en/2615830 In S7-200 you read and write to V-memory. And in S7-300 you read and write to bytes declared in hardware configuration. Because you use CP342-5, you'll have to use DP_send and DP_write. The location of the bytes depends on slave address S7-200. Best regards Wizard |
12/21/2006 1:44 PM | |
Great everything is working |
