1/11/2010 7:54 AM | |
Joined: 9/28/2005 Last visit: 7/24/2025 Posts: 2957 Rating:
Hello, I've downloaded an example and compiled it without any problems. Have you changed CPU type in project ? What version of Micro/WIN do you have ? In any case you should upgrade your Micro/WIN version to latest. Instructions and download is here. Also try to redownload project in case it is corrupted. |
Best regards, |
1/11/2010 3:10 PM | |
Posts: 4 Rating:
Hi, and thank you for your reply. I'mm using STEP 7-Micro/Win v4.0.0.81 The PLC type is the same the CPU version varies. The project was using CPU Version 2.00 and my CPU version is 2.01. My plc 224XP cpu version 2.01 Siemens Project plc 224XP cpu version 2.00 I can't see what the problem is. The file name is (Set1_s7-200_V1d2_en.wmf) I'll try an update Step 7-Micro/Win to Service Pack 7 and see how it goes. |
1/11/2010 5:14 PM | |
Posts: 4 Rating:
Problem solved. Needed an update for STEP 7. Siemens provided me with an older version .. Thank you .. |
