12/28/2018 10:10 AM | |
Joined: 5/24/2018 Last visit: 3/4/2024 Posts: 1 Rating:
Hello, I want to connect the BW500 to TIA Portal with ethrnet connection and i need the GSD files for TIA on ethernet. I have the ethernet smartlinx card installed. Thank you Alex ------------------------------------------------------------------------------------------ |
Last edited by: AlexGT13 at: 12/28/2018 10:38:35 AMLast edited by: CS Moderator at: 12/29/2018 2:00:56 PMNew subject after splitting |
12/29/2018 3:29 PM | |
Joined: 9/27/2006 Last visit: 9/16/2025 Posts: 12409 Rating:
Hello Alex; What model number is your installed smartlinx communication module? For Profinet, you would need a 7ML1830-1PM module. This link will provide the data disk for the Profinet smartlinx, with the gsdml file and an application example for the S7-1200 client. Here you will have a general document on all smartlinx variants: SmartLinx Profinet Application guide: Hope this helps, Daniel Chartier |
