4/4/2012 2:14 PM | |
Posts: 90 Rating:
So is there any other way to be sure about your program which is tranfer data between to PLCs, before using it in real situation? |
4/14/2012 1:24 PM | |
Joined: 1/28/2009 Last visit: 8/31/2025 Posts: 6874 Rating:
Hello , As far as I know, PLCSIM is capable of simulating S7 connection between 2 connection partners.You can try your configuration with set up illustrated in the following link: How do you simulate communication between two CPU modules? If it does not meet your requirements, check the sample programs available for different communication scenarios to verify your config and program. I hope this helps Best regards, Hamid Hosseini |
