8/6/2025 2:23 PM | |
Joined: 2/1/2010 Last visit: 9/15/2025 Posts: 213 Rating:
This is impractical (and likely impossible) to solve direct in CFC. I suggest you need to create a custom block (in SCL, etc.) in order to deliver the solution. As array is not supported in CFC you need to connect to the DB or bulk I/Q space from a PN or DP slave which will need parsed from the custom block. Architecture of such a block could be easy or complex depending on the details of your data. |
If my post helped you, please rate. Thanks. |
