1/22/2010 4:58 PM | |
Joined: 4/5/2006 Last visit: 7/30/2025 Posts: 917 Rating:
Hi Manjeet , strange problem: connection without right license should be works anyway To merge license you need open ALM and select license you have to merge, then select "License Key" menu -> "Upgrade" full description described in ALM help -> Installation -> Upgrade of license Regards |
2/5/2010 5:10 PM | |
Hi Manjeet , sorry for late, i has been busy on the plants... did you merged license? license are ok? (check them using ALM) what about CP1613: can you see any problem? i didn't understand if CP is working fine and connection ONLY is the problem, or CP are bad too. which version are you using? can you post some screenshot to explain better what is the trouble? regards |
