11/16/2016 9:56 AM | |
Joined: 7/9/2015 Last visit: 8/29/2025 Posts: 4443 Rating:
Hi, first I checked you CP343-1 if it compatible with you PLC - it does. It´s just a guess: Your CP343-2 is connected to slot number 5, this means it uses base Adress 272 and a length of 16 bytes. Please check if there is any other Adress in this area. In most CPUs (for example, the CPU 315-2DP, 318), the slot-oriented addressing can be modified with STEP 7 configuration (HW Config). Also check manual on page 24: https://support.industry.siemens.com/cs/de/en/view/5581657 Regards, Towome |
