1/21/2022 12:40 PM | |
hi jonutt, have you seen this application sample: Configuring standard machines in TIA Portal (configuration control)There you should find anything thats possible. The probelm with your query is, that a device is deactivated, so the PLC is not looking for them. Otherwise the PLC is searching for this device and showing an error. So if you want a recognition of a device that is not activated at the moment, you need to go to the start-up routine. hope this helps, regards, |
FCK WAR! |
