8/5/2009 12:11 AM | |
Posts: 2661 Rating:
Hi Imtech, For PCS7 standard objects you can change the format by adjusting the properties in the block icons. Example of MEAS_MON attached. You can make your own IO field customized objects along similar lines. Regards AttachmentIO_Format.pdf (342 Downloads) |
