1/16/2023 2:01 PM | |
Joined: 8/3/2009 Last visit: 9/5/2025 Posts: 16343 Rating:
Hello you could use address multiplexing with symbolic adressing and UDTs if you have optimized dbs (then you would have to use an array) https://support.industry.siemens.com/cs/ww/en/view/109798671/83078586123 Of course you could also use adress multiplexing with absolute adresses but then you would have to use HMI UDTs both is posible and should fit to your usecase Bye Murof |
