11/3/2022 12:22 PM | |
Joined: 1/28/2009 Last visit: 9/15/2025 Posts: 6875 Rating:
Dear user, Removing a Sync Module from a working CPU can STOP it if you did not download all error DBs in each CPU. Changing a SYNC module on a MONO CPU while considering all precaution will be trouble-free , But we always do the risky decision when it is strongly needed.
We found in practice for CPUs V4.5 , when the one LED on a SYNC link is dead we first try to change the module with lit LED. If you carefully read the diagnostics buffer of the CPUs , you can find the exact module by the diagnostic address reported. I hope it helps, hdhosseini AttachmentSYNC.zip (1161 Downloads) |
Last edited by: hdhosseini at: 11/03/2022 12:25:34Last edited by: hdhosseini at: 11/03/2022 12:29:08 |
