3/9/2012 11:41 AM | |
Posts: 93 Rating:
Another application I know is the power distribution. It's used in substations to clarify which circuit breaker has tripped first and what happened consequently. Best regards. H-H Dear all, In one of my application,I am too using the "Precission time stamping" method. I have configured the hardware as per mentioned in the manual. I am trying to generate the alarms on OS, but it is not generating. My querry isweather I can generate the alarm using the PLCSIM ? or Ineed tohave the actual hardware to check my stuff. |
Last edited by: O_Moderator at: 3/12/2012 10:33 AMLast edited by: O_Moderator at: 3/12/2012 10:32 AMnew subject after splitting from /tf/WW/en/Posts/58849#top |
3/15/2012 8:18 AM | |
Joined: 10/10/2005 Last visit: 1/29/2025 Posts: 1940 Rating:
Hello, there are some informations in the internet which do you can also use with S7-PLCSIM. http://support.automation.siemens.com/WW/view/de/5416665 http://support.automation.siemens.com/WW/view/de/38006554 With best regards |
