8/20/2006 10:45 AM | |
Posts: 13 Rating:
yes there is not stop in the configuration, sometime when i disconnect the s5 rack, the cpu stop , and sometime the cpu doesnt stop |
8/21/2006 7:35 PM | |
Posts: 13 Rating:
this is my disgnosis buffer, i have reproduce the stoping of the cpu by doing this 1- switch off a s5 rack 2- disconnect DP cable 3- switch on s5 rack et reconnect dp cable in same time 4- the cpu stop 5- i retstart cpu "stop run" after that a each switch off-on s5 rack the cpu stop it is like the cpu "forget" an event disconnetion reconnection my s7project file is too big can i send you the file by mail ?? thanks AttachmentServiceData_CPU 416-3 DP_MPI2_R00S04renamein.txt.pdf (1032 Downloads) |
8/22/2006 4:23 PM | |
Posts: 13 Rating:
sorry just rename pdf file in .txt file i send you the configuration file in the next message few minutes AttachmentDiagPlantageChantier.zip (952 Downloads) |
