9/19/2007 7:50 AM | |
Posts: 84 Rating:
Hi everybody |
9/19/2007 1:17 PM | |
Posts: 1275 Rating:
Hi, Are you using WinCC, WinCC Flexible or ProTool???? Danielle |
9/23/2007 10:25 AM | |
Posts: 84 Rating:
Hi I use WINCC 6 SP 4, Is it possible to make horizantal status bar in WINCC Flexible ? |
10/20/2007 3:08 PM | |
Joined: 10/31/2006 Last visit: 9/21/2022 Posts: 134 Rating:
Here is an example you can try. You will have to do some scaling calculation and also check the limits of your value so that it does not overlap. I have basically adjusted the height of a rectangle ( by connecting it to the tag value ) and placed it behind a circular polygon. Once again create some internal tags to simulate the values. I have used increments of ten to adjust the height Hope this gets you going for what you want to do. Regards Shane AttachmentSlider.zip (195 Downloads) |
