3/1/2011 1:51 PM | |
Posts: 2964 Rating:
Hello Deep, When you refer the manual...Yes it specifies dual axispower module with rated/peak current capacity as 9/18Amp but look in the manual of Simodrive 611 digital Configuration Manual Drive converters. pg no88... 2*25 means the momentary peak current of 25A...check this document may be useful 6SN1123-1AB00-0BA1 2x25A, SIMODRIVE 611 POWER MODULE, 2 AXES, 25 A, INTERNAL COOLING, MOTOR RATED CURRENT: FEED = 9 A MAIN SPINDEL = 8 A Regards, Ekalavya Attachmentpower module.pdf (356 Downloads) |
