8/19/2025 7:45 AM | |
Joined: 8/3/2009 Last visit: 9/4/2025 Posts: 16343 Rating:
Hello AutoGen_1b72d perhaps this FAQ can give you some useful information: https://support.industry.siemens.com/cs/de/en/view/58667814 on WinCC side we need to know which WinCC Version do you use? (and of course the WinCC in ths FAQ is a different one so it does not fit 100%) Bye Murof |
Last edited by: Murof at: 08/19/2025 07:46:42If this Information really helps, you could use the Rate function |
8/19/2025 1:23 PM | |
Joined: 8/19/2025 Last visit: 8/22/2025 Posts: 2 Rating:
Thank you for your reply. It's wincc version 8.0 not tia portal. The example is useful, but I can't see the sample. |
8/28/2025 11:27 AM | |
Hello there is also a very old Examples in this FAQs: https://support.industry.siemens.com/cs/de/en/view/1138415 https://support.industry.siemens.com/cs/de/en/view/22531788 It should also work in the newer WinCC Versions. Perhaps it helps Bye Murof |
