2/25/2010 3:47 PM | |
Joined: 3/14/2008 Last visit: 9/11/2025 Posts: 2216 Rating:
Ok, I've got information on a Siemens page regarding diagnostics and hardware issues. In there I found the following text: Notes:
Siemens has a problem with explaining things or I have a problems because I don't understand Siemens. ---> Can I use the IM467 module or not?! IT says thatis not released (so is S7300), butcan't be replaced in run mode... |
Last edited by: Oreca at: 2/25/2010 4:21 PMIf I could help you, you can use the RATE button. Thank you. |
2/26/2010 8:29 AM | |
Hello Phantom thanks for your replies. I do not need full functionality. I'm only using it for connection to danfoss drives... write QW and read IW. and present status at OS system. That is nice to hear... |
