10/11/2018 3:44 PM | |
Posts: 13 Rating:
Dear all, We are exploring the possibility of creating Material Take Off estimations (MTO) directly from the P&ID. The target is to be able to create MTOs without a 3D model just from the P&ID. (Length and elbows would be estimated) but other components as flanges, tees, nozzles, reducers and so on could be extracted if the P&ID is detailed enough. We are trying to configue the "material management assistant" / Creating material from P&ID Data. Manual can be found here After creating the configuration object and following the steps. COMOS does not allow to open the material management. A warning message appears "no configuration object was found". Does someone have experience with this plugin? Many thanks in advance |
10/19/2018 10:12 AM | |
Joined: 6/30/2014 Last visit: 8/4/2025 Posts: 475 Rating:
Hallo, would you have a look and follow the steps of this manual attached here? That may help you. With best regards, SuperPippo AttachmentMaterial_Management_enUS.pdf (353 Downloads) |
