6/17/2010 1:29 PM | |
Joined: 9/11/2006 Last visit: 3/17/2022 Posts: 168 Rating:
Hi check the following setting : Select WinCC Computer Name > Properties>Paramteters> PC Clock setting and Time base To synchronize time between the PLC and wincc look at the following link: http://support.automation.siemens.com/WW/view/en/22867760 If the diffrence between the two times is the same as the difference between your time zone and GMT you can look under help to match wincc to the correct time zone: WinCC Information Systm> Working with WinCC >Creating and Editing Projects>Setting Time in WinCC |
6/25/2010 1:54 PM | |
Joined: 2/20/2010 Last visit: 6/2/2025 Posts: 104 Rating:
Thanks Bronze... |
