4/11/2018 2:31 PM | |
Joined: 10/8/2016 Last visit: 1/23/2021 Posts: 17 Rating:
Hello, With a S7-1200, i want to read total of active energy export. I have no problem to read in the PAC2200 with a block "MB_CLIENT_DB" What should I put in "MB-DATA-ADDR" ???? I read in the maunuel PAC2200 : --Deleted Link-- Following an example :
--Deleted Link-- My calculation MB_DATA_ADDR : 40001 + 505 = 40506 The modbus addresses are identical for the PAC2200 as for the PAC 3200 Read with webserver --Deleted Link-- My MB CLIENT in Tia portal:
--Deleted Link-- My bloc
--Deleted Link-- Thanks for your help. Pierre AttachmentPictures.zip (490 Downloads) |
Last edited by: finemeca at: 4/11/2018 2:32:37 PMLast edited by: Jen_Moderator at: 4/12/2018 8:11:45 AMDeleted links and added all files as an attachment. |
4/11/2018 2:35 PM | |
Joined: 12/18/2014 Last visit: 9/16/2025 Posts: 35964 Rating:
Take a look at this Siemens FAQ: Data Communication between S7-1200 and SENTRON PAC3200 via MODBUS TCP (Set 22) Maybe it can help. |
4/11/2018 2:46 PM | |
Posts: 3093 Rating:
Hello finemeca, Regards, |
4/11/2018 4:29 PM | |
Thank you but it's the value of "total active energy export" that I want. It works for my voltage, amperage. Thank you for your help ! |
4/13/2018 12:28 PM | |
Hello, Do you have an idea for the next ? I block |
