1/9/2019 8:55 AM | |
Posts: 33 Rating:
Hi, I try to write the Example Image provided in the link to my SD card and it worked at first. Then when i try to turn on the IoT 2040, i saw the SD-LED didn't blink, so i read somewhere else that I need to re-write the SD card. And then, there is this Error 5: Access denied. I try all the methods such as go to properties=>security=>owner=> but there is no edit based on other website. It's just written "everyone". Another way i did was using command prompt=>run as administrator and it didn't work. Please help. Thank you ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 1/11/2019 6:52:36 AMNew subject after splitting |
1/9/2019 9:40 AM | |
Joined: 4/28/2015 Last visit: 4/24/2025 Posts: 3345 Rating:
Hi, did you try to ping the IOT2000 after turning it on? Or did you just assume that it isn't working? When do you get this error 5: access denied? Writing the image again or when you try to get connect to the IOT2000? Did you follow this document? Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
