9/28/2009 6:13 PM | |
Joined: 4/5/2006 Last visit: 7/30/2025 Posts: 917 Rating:
Hi marianr , seems a lil hard to answer with few info. If you look in standard faceplate you can see object called @level5 & @level6; if you started to built your faceplate copying from standard, you forgot to rename that object (insert again @ at begin). If the reason is not this one, i think need more info like some screenshot or configuration Regards |
