9/21/2017 12:52 PM | |
Joined: 12/27/2006 Last visit: 8/26/2025 Posts: 1200 Rating:
an PI regulator. is for changing values (inputs / outputs). The I part of the PI reulator will change tho output even when the inputs are constant the same. If you want a fix value to an analog output then you can take a "Mathematical insrtucting" block AttachmentCircuit Diagram1.zip (298 Downloads) |
