7/13/2012 2:01 PM | |
Joined: 4/24/2006 Last visit: 7/31/2025 Posts: 9027 Rating:
Hello Giba100, The CPU 315-2AF03 is an old one and not supported by TIA Portal software Which devices and modules are supported by STEP 7 Professional V11 and WinCC Professional V11? About panel, can you explain what software you are using? (TIA portal vx, WinCC basic/comfort etc.) If you want to use Comfort panel, you need at least WinCC Comfort. Best regards, Wizard |
7/13/2012 2:11 PM | |
Joined: 10/10/2005 Last visit: 1/29/2025 Posts: 1940 Rating:
Hello, which version of TIA Portal have you installed? V11, V11+SP1 or V11+SP2? But I think, the CPU with MLFB 6ES7315-2AF03 is not supported. Which MLFB-number has the KTP 400 Comfort. Please see the list of supported moduls by the following FAQ: http://support.automation.siemens.com/WW/view/de/50029532 With best regards |
7/13/2012 8:15 PM | |
Posts: 4 Rating:
Ok thanks a lot for quick response, topic to close. |
