1/23/2012 12:19 PM | |
Joined: 9/12/2011 Last visit: 12/4/2024 Posts: 61 Rating:
Thank you UMENCHO for your support ... i did it but i have a new problem with another drive SIMOVERT VC part no. 6SE7131-2EC61-3BA0-Z i did the same steps for uploading parameters too ... but when i set up an USS online connection; the drive monitor find the drive but it can't identify drive's unit type and version (see attachment picture) so how can i solve that problem ... regards. |
Last edited by: O_Moderator at: 1/24/2012 9:37 AMLast edited by: O_Moderator at: 1/24/2012 9:31 AMnew subject after splitting from /tf/WW/en/Posts/67857#top George Awny |
1/24/2012 11:49 AM | |
Posts: 31 Rating:
hi GOG, what is the value for the parameter no:60 (0-7) if the value is 0 it will show ???? on drive monitor change the value to 1 and try to connect. |
1/29/2012 7:01 PM | |
Posts: 41 Rating:
Hi, Please check your serial cable connectivity also check the value entered in P053 (Parameter Access). It should be 6 (PMU+serial interface) |
