9/22/2009 10:44 AM | |
Posts: 125 Rating:
Hi ercag, this library is not standard of PCS 7. If you use the Library "Device Library IEC 61850", please contact the collegues ofIT4Industry. http://www.industry.siemens.com/industrial-services/it/en/products/simatic_add_ons/s7_iec61850.htm#toc-benefits |
9/22/2009 2:41 PM | |
Joined: 10/9/2007 Last visit: 8/18/2025 Posts: 1281 Rating:
Hi Ercag If you don't know what is Dataset, it will be hard for you to configure, test, check and correct problems. Take a look at this manual, it has usefulinformations about datasets and other parameters you need for configuring your S7 blocks. http://siemens.siprotec.de/download_neu/software/DIGSI_4/Manual/IEC61850_STARTUP_A2_EN.pdf Mike J |
Energy Automation products: Sicam, Siprotec, Digsi |
