1/3/2023 6:49 PM | |
Joined: 2/1/2010 Last visit: 9/3/2025 Posts: 212 Rating:
I have never used the PCS7AITC block with ET200SP IO, however according to the manual, you can only use it for TC mode, RTD mode is not listed. Try using standard PCS7AnIn in the 'old' way and see if that works? Reference PUD Pcs7AITC help: The block is used for the following applications:
If my post helped you, please rate. Thanks. |
