1/30/2011 2:34 PM | |
Joined: 10/7/2005 Last visit: 9/3/2025 Posts: 3049 Rating:
Hello 256 you say you have an EEPROM, if so, you can use the 100U itself to burn a copy of theprogram in the RAMonto the EEPROM. Have a look at chapter 4.4.1 of the 100U manual which explains how to do it via the "Copy" key on the CPU. I hope this helps |
Cheers |
1/31/2011 8:23 AM | |
Hello 256 allow me to answer you with questions: have you considered checking the 95U manual for the answer (you'll find it via a searchat https://support.automation.siemens.com)? |
Cheers |
2/1/2011 8:34 AM | |
Joined: 4/22/2010 Last visit: 3/31/2025 Posts: 5697 Rating:
He means it's all in the manual, you will find it here: http://support.automation.siemens.com/WW/view/en/1091648 In the attachment the right page. Attachment95u-eeprom.pdf (974 Downloads) |
Problem solved? |
