5/2/2025 11:09 AM | |
Joined: 8/3/2009 Last visit: 9/5/2025 Posts: 16349 Rating:
Hello AutoGen_8925449 If you still have got problems you should install the latest Update for your WinCC Version and check also if you can create a new project Check also the compatibility with the OS you are using: https://support.industry.siemens.com/cs/de/en/view/64847781 Bye Murof |
5/7/2025 12:57 PM | |
Hello you can try to reset some basic data and check if the project then opens: (But make a backup of the project first https://support.industry.siemens.com/cs/de/en/view/109763043 https://support.industry.siemens.com/cs/ww/en/view/109779249 Bye Murof
