2/14/2022 1:55 PM | |
Joined: 1/29/2022 Last visit: 2/15/2022 Posts: 2 Rating:
Hello, As mentioned in the title I'm trying to upload a backup I've downloaded from a person who has the same machine and control. Here is the video of the behavior video upload I can manage the upload with start and stop on the sinumerik so the machine seems connected. But at the end there isn't any upload comfirmation and the empty storage volume stays the same. Here is the cable schematic I used. 1-1 2-2 3-3 4-6 5-7 6-20 7-5 8-4 Attachmentfiles.zip (213 Downloads) |
Last edited by: Legnova at: 02/14/2022 14:04:40Last edited by: Jen_Moderator at: 02/15/2022 09:16:25Removed link and added all files as a zip file. |
2/14/2022 9:18 PM | |
Joined: 10/17/2007 Last visit: 9/12/2025 Posts: 4449 Rating:
Answer you-- 1st of all I NOT suggest load Video 2nd I don't quit understand your problem. 3rd I attached detail step-by-step to load 810/820 for you 4th. I always use Siemens PCIN (also now WinPCIN) in ext. PC as SW. cable should be easy --google RS232 25 pin to 25 pin , or 9 pin to 25 pin more important --you must going 'Initial Clear Mode" then start transfer Attachment810_820 reload.pdf (243 Downloads) |
If you like my comments please |
