5/16/2019 4:08 PM | |
Joined: 10/7/2009 Last visit: 8/8/2025 Posts: 266 Rating:
Hi, Have you read this document? How does the Modbus-Communication of the WP231 work Best regards, Yu-Wen Attachmentmodbus_communication_wp231_en.pdf (484 Downloads) |
Last edited by: Jen_Moderator at: 05/17/2019 09:47:35Added PDF file as an attachment. |
5/17/2019 10:30 AM | |
Posts: 3 Rating:
yes and follow the steps in this document but calibration weight (1024...41025) can't changed 1- i_CMD_CODE = 1 920(40920)=1
4- i_CMD_CODE = 4003 920(40920)=4003 5- i_CMD_CODE = 2 920(40920)=2 |
5/17/2019 11:01 AM | |
Joined: 1/4/2007 Last visit: 8/26/2025 Posts: 1190 Rating:
Hello BADR3, Well, in the past, I „played“ a little bit with S7-1500 and WP231 via Modbus TCP. Attached you can find my test TIA-project. In my project it was possible to read and write data. I executed my commands manually with the Watch table „MODBUS_Watchtable“. I don’t know, but maybe my test TIA-project will help. You have to change the ".txt" to ".zap14". Best regards Siwarexi AttachmentModbus_WP231_S7-1500_en.txt (437 Downloads) |
5/27/2019 9:53 AM | |
Posts: 3 Rating:
Hello Siwarexi, if i use one block client to read and write, i can read and change all parameter
AttachmentTCP IP 1500.txt (409 Downloads) |
