4/26/2016 10:22 AM | |
Posts: 31 Rating:
Hello, The following document may help you: Regards, Craig. |
4/26/2016 10:29 AM | |
Joined: 11/21/2007 Last visit: 7/25/2025 Posts: 2326 Rating:
Hello What are the versions of the two blocks. I believe that the German and English Blocks of Identical Version should be interchangeable. However you should not replace block of one version with another. ( You can check the versions in Block list ) as new versions may have additional functionality and may require to be handles differently. To Understand what has changed in FB2 ( Or other blocks ) in different versions : SIMATIC NET Program blocks - Version history of the SIMATIC NET program blocks for SIMATIC S7 CPs - Reference Manual FB-2 : Section 1.9 Page-21 Hope this helps Cheers Navnag |
There is no such thing as the last bug in a program |
4/26/2016 10:35 AM | |
Joined: 9/18/2013 Last visit: 2/20/2024 Posts: 203 Rating:
Hello, I think you shall look for the version of FB2 in both libraries. They shall have changed the version of FB2 if they added any changes, but if they have the same version then you can replace them, you will find it in the object properties of FB2 -> General - Part 2 But if I were you I won't proceed in this action before contacting siemens support for more confirmation |
4/26/2016 2:37 PM | |
FB_P_RCV is a part of the CP_PtP Library. ( The latest version that I have is V2.0 ). |
Last edited by: Navnag at: 4/29/2016 4:01:14 PMLink Corrected There is no such thing as the last bug in a program |
4/28/2016 2:07 PM | |
Posts: 18 Rating:
Hi Guys, I don't seem to have access to the PtP library.... where can i find this? Or am I doing something wrong? Many Thanks |
4/28/2016 2:18 PM | |
Joined: 4/28/2015 Last visit: 4/19/2025 Posts: 10876 Rating:
Hello Pablo, in Simatic Manager -> File -> Open -> Libraries |
With best regards... |
