9/1/2008 7:16 PM | |
Joined: 11/21/2007 Last visit: 7/25/2025 Posts: 2326 Rating:
Dear Pandiani Thanks for your interest. I am attaching the table for your reference. I had written a FC in STL in STEP7 for use in SIMATIC S7 for the same function. Can I use it in PCS7 Thanks Navnag AttachmentSteam_Table.PDF (854 Downloads) |
There is no such thing as the last bug in a program |
9/2/2008 10:24 AM | |
Joined: 10/31/2005 Last visit: 4/22/2025 Posts: 366 Rating:
Navnag, I had this in mind. Instead of interpolation I would use least square approximation (polynomial fit). Look at Excel sheet. So you can make FB that calculates pressure, spec. volume... when you know mathematical relation between them. This way you avoid using lookup tables. If that suits you, I can calculate polynomial coefficients more precisely Best regards, pandiani AttachmentTables.zip (687 Downloads) |
9/4/2008 7:33 AM | |
Navnag, what happened? Is this approach good to you? I'm very interested to learn how you resolved your problem. |
9/4/2008 7:32 PM | |
Navnag, just keep us informed... Regards... |
9/10/2008 5:16 PM | |
Navnag, did you have testing as planned? I'm really curious to learn what you've come up with. Regards, Pandiani |
