10/28/2024 8:50 AM | |
Joined: 1/21/2013 Last visit: 8/29/2025 Posts: 4087 Rating:
Hi MorneF, Since, according to your post, you are using the latest updates, I would recommend that you contact technical support. I would not rule out the possibility that there is a bug here. It would be interesting to see how you use the symbolic IO field. Is it just placed on a screen, is it in a group, or is it part of a faceplate? This could be important in reproducing it. In the past, I have seen problems using the IO field within a group. But that has been fixed. Kind regards |
