11/7/2014 9:12 AM | |
Joined: 10/18/2012 Last visit: 9/8/2025 Posts: 225 Rating:
Hi tyleong, if you install normal (Office) Windows 7, you probably miss some drivers for your IPC547C. These drivers are included in the special CDs / DVDs that are delivered with the IPC. To get the required CDs / DVDs with the drivers I would ask your local contact from Siemens for it. There is also some information about upgrading from Windows XP to Windows 7 here: http://support.automation.siemens.com/WW/view/en/89056082 and here: http://support.automation.siemens.com/WW/view/en/82555422 Hope that helps? xnor |
11/10/2014 8:27 AM | |
You need the Drivers for Windows 7. The old driver-CD with Windows-XP drivers will not help. |
