8/21/2025 9:29 AM | |
Joined: 8/3/2009 Last visit: 9/5/2025 Posts: 16349 Rating:
Hello AutoGen_1163912 where do you use the tag trigger? Do you use the scheduled task to trigger this script (is it a global Script?) Or do you use a property script in a screen context and do you use a local script or also a global script? and yes Trace outputs would help us to find the reason for the issue: https://support.industry.siemens.com/cs/de/en/view/109777593 Bye Murof |
