6/17/2013 11:39 AM | |
Joined: 1/29/2006 Last visit: 8/16/2025 Posts: 451 Rating:
Hello, TechTeam, and thank you very much for good wishes! I have attached a small picture about mechanical configuration of system. I expect, that after use of gearbox, we would be able to increase tension in belt and get better stiffnes; now, tension in belt had to be reduced, because system, driven directly from motor axes, even could not move the trolley, if the belt was streched as much as possible! uel123. AttachmentForum.pdf (415 Downloads) |
