9/29/2022 10:23 AM | |
Joined: 8/31/2022 Last visit: 9/16/2024 Posts: 11 Rating:
Hello everyone, i'm struggling in issue wth VoT. I'm working with TIA V17 update 4 that have resolved the problem relative the FAQ 109805463. I'm working on a multi PLC project with 8 identical 1515-2PN FW 2.9.4. With 7 of the 8 PLC I don't have problem, but the last is showing a blank page after the login. I've tried to do the following: -Delete and Reload the web application; -Delete web application and download one with just one page; -Restarted the PLC different times; -Delete Browser cache and data; -Used another device to access; Only after I've found that when loading the Login page the web applciation give some errors in webscreenitems.basic.min.js. (see BAD.png attachment). Any suggestion? Thank you in advice, LF. AttachmentScreenCaptuers.zip (610 Downloads) |
Last edited by: luciano.fab at: 09/29/2022 10:24:58Last edited by: luciano.fab at: 09/29/2022 10:26:25Last edited by: luciano.fab at: 09/29/2022 10:28:22 |
9/29/2022 12:48 PM | |
Little update: if I reset the CPu and Format the MMC the problem fix, but at first update of the web application the problem come back. This happen only on this CPU, attached the service data. Thank for any suggesiton, Have a nice day, LF. Attachment6ES7 515-2AM01-0AB0 S C-HDLP79562016 20220929 124314_2.zip (486 Downloads) |
10/3/2022 10:19 AM | |
Joined: 9/23/2005 Last visit: 9/3/2025 Posts: 4416 Rating:
Hi, did you tried to use upd 5? https://support.industry.siemens.com/cs/br/en/view/109784441 |
Denilson Pegaia |
11/4/2022 2:58 PM | |
After a long investigation I found that the problem is the corruption of *.js files during the download. Attached the corrupted files from the PLC webserver and the same files from PLCSIM Advanced running same project (only recompiled). It's probable that I need a new update of TIA portal to fix this. Anyone can suggest a way to avoid the files corruption?
AttachmentjsFiles.zip (588 Downloads) |
